Defaults and Cheat Keys - AAS (Analog Address System)
Question
What are the methods to deep clear or reset an Analog address processor to factory defaults?
Answer
To restore default settings on the AAS processor:
Hold Down one of following buttons and toggle Reset\Normal switch to perform the function.
[Dimmer Up]
Rebuilds all defaults (1-to-1 Patch, Panic, Worklight)
[Dimmer Down] RAM Test
[Exit] EEPROM Test
[Enter]  Clears all patch
While in Monitor Mode:
Users can make the following changes by pressing the button.
[Dimmer Up] Toggles Worklight circuit on/off
[Dimmer Down] Toggles Panic circuit on/off
[Edit Up] [Edit down] Toggles through the 8 take control lines
