AAS (Analog Address System) - Black Lines Across Top of LCD, Intermittent Output
  • There are black boxes across the top of the display, and the AAS is not working.
  • The AAS Resets itself.
  • Wiggling the Reset switch lever (S1) causes the AAS to reset.
  • Moving the Reset swithc lever (S1) does nothing at all.
The S1 Reset switch will likely need to be replaced.
Please contact your Dealer or ETC Technical Services to set up an RMA.
