DAS and Recording Submaster/Snapshots Looks onto Faders.
Set the "Look" at lighting control console.
Lower all other channels to '0' when programming including the master on that wall station.
Raise channel to be programmed to full.
Press and Hold record button until LED flashes.
Note: Some systems only program from other station sliders and not from incoming DMX.
Other Common Methods to Record Snapshots:
With all of the faders at Zero:
  • Press the "Program" (could be called "Record") button once, run the desired fader up to full and back to zero
  • Press and hold "Program", run the desired fader up to full and back to zero
  • Press "Program" once. Then, press and hold "Program" and run the desired fader to full and back
  • Press the "Program" button once, run the desired fader up to full
  • Press and hold "Program", run the desired fader up to full and release "Program"
  • Press "Program" once. Then, press and hold "Program" and run the desired fader to full then release "Program"
Custom Configuration:
Several sites have custom configured stations and station behavior that may not fall into the above options. If after trying all of the above choices, you still cannot snapshot, please call us for further information.
