Latch/Lock Application to Different Control Sources
Question
When an output's mode is set to Latch/Lock on my Sensor IQ or Echo Relay Panel, do the Latch/Lock ranges and time setting apply to all possible control levels and methods?
Answer
Latch/Lock mode only affects the output's response to DMX and sACN levels. The output will behave as if its mode is set to Normal when controlled via any of the following methods:
  • Arch / Echo
  • Set Levels / Local Levels
  • Panic
  • Emergency
  • Contact Input
