Replacing the Control Cards in an Echo Relay Panel Feedthrough
I need to replace the control cards in my Echo Relay Panel Feedthrough (ERP-FT), and I am unsure how to do this.
First, you will need a replacement control card. Parts can be ordered through an ETC Dealer.  If you believe your panel is still under warranty, you should contact ETC technical services to inquire about whether a warranty replacement is possible.
Distro Part numbers:
ERP-FT 24 / ERP-FT 48 Top Card:
P/N 7123B5635
ERP-FT CONTROL 2 ASSY
ERP-FT 48 Bottom Card:
P/N 7123B5735
ERP-FT CONTROL 2 LOWER 24 ASSY
Once you have ordered a new control card, follow the instructions below.
The below pictures are for the top assembly of a ERP-FT. If you're replacing the bottom card on a 48 circuit panel, the process is the same, but the card is mirrored in orientation.
  1. Power down the rack!
  2. Remove the door that blocks access to the relays.
  3. Unplug the blue and red two-wire harnesses that connect each relay to the control card.
  4. Unplug the power harness and CAN bus cables that run to the processor.
  5. Remove the screws that hold in the control card.
  6. Insert the new part, ensure it's screwed down firmly, then plug all wire harnesses back in.
