Does Preset Record From A Sensor IQ Capture Levels From Other Echo Panels In The Same Space?
Situation
I am trying to record an Echo preset from my Echo Power Control Processor, but I am uncertain if levels in other Echo racks will be included in the preset as well.
Each Echo rack (ERP/ERP-FT/SIQ) is only capable of recognizing its local levels when recording a preset. Only local circuits assigned to the same space as the preset will be recorded.
This being said, a record command from any Echo Device will broadcast that command on the EchoConnect bus to all connected Echo Devices.  So a preset recorded on the Echo Relay Panel will include levels in other Echo Racks that are assigned to the same space and are connected to the EchoConnect Bus.
