Unison Control Module/Light Manager Release Notes v1.52a Software Limited Release
Changes between released 1.5 and beta bug-fix point release 1.52a
Bug Fix:
If you have a configuration with a macro that has a step that sets a station property, and then delete that station, and then run that macro, Unison will crash.
If you have a configuration with a macro that has a step that sets a channel property, and then delete that channel, and then run that macro, Unison will crash.
Make a stand-alone master more aggressive about what zones it controls
DAK (Disney Animal Kingdom):
Fix new (Sensor 3.1) D20AF problem where both dimmer numbers are the same (now ignore identical dimmer number in second half of module)
Hold off on sending ETCLink messages until receive channel is clear (possibly fix ETCLink stack crash when lots of dimmers are in error)
Make sure we don't set Rack::NumberOfModules (nMOD) to more than 48
RIO (Rio Casino):
Make Serial Access Protocol echo ID byte back
Make SAP baud rate settable
Bug fix: Presets activated by the serial protocol within a section were not getting their level set to 100%
