Infrared (IR) Remote Compatibility between Unison Legacy and Unison Paradigm
The legacy Unison remote and Unison Paradigm heritage remote are the same hardware, however some changes were made to the remote and button placement that will affect their functionality. Both remotes are compatible with Legacy Unison hardware, however the heritage remote must be used for Unison Paradigm systems.
If you have a legacy Unison System provide the 7081A1357 or 7081A1358 remote. When stock is depleted use the Paradigm part numbers below.
For Unison Paradigm Systems provide the 7181A1357 or 7181A1358 remote.
The placement of the 10th button is changed from the 7081Axxxx remotes.  The 10th button on the Legacy remotes will not function with a Paradigm Control System.
