Unknown Device appears when patching via RDM
When using RDM to patch devices to ColorSource and EchoTouch, devices are discovered but appear as "Unknown Device".
Explanation of Issue
ColorSource (and Eos) look up the fixture personality using the Manufacturer, Model, Mode ID numbers, and the reported DMX footprint that the device provides via standard RDM commands. ColorSource only displays the name of the device if it has been found in the Fixture Library and it can be patched automatically.
The “Unknown” indicates that the console does not know which of the 32,000 personalities in the library it should use.
ETC can update the Fixture Library when users report this issue and provide a showfile where they have manually assigned the correct personalities.
Once the user assigns a Personality, all other fixtures of the same type and mode should become auto-patchable.
(This link is stored in the showfile, in the play > patch > personalities array, manufacturer, model, and mode fields.)
  1. Confirm that the RDM devices have personalities in the ColorSource Fixture Library by searching at https://fixture-library-hub.etcconnect.com/ (be sure to change the Platform to "ColorSource / EchoTouch"
  2. For each "Unknown Device", manually select the correct personality from the Fixture Library
  3. Confirm that the fixture(s) operate as expected.
  4. Save a showfile (of type .lsf)
  5. Email that showfile to colorsource (at) etcconnect (dot) com with a message to indicate which fixture(s) should be updated in the ColorSource Personality Library
