Can I Control All Effects on a Single Fader?
Question
Is it possible, when using several effects, to control features of those effects from a single fader instead of multiple faders? Such as a Global Effect Master?
Answer
Yes it is! As of Eos Family Software v2.7.2, you can assign a fader to be a Global Effects fader by using the "Fader Config" tab.  Once set at Global Effects, you can filter down to specific effects, effects running on channels only, in cues only, in submasters only, and other filtering options.
NOTE: If no filters are applied, the fader will master all effects.
For more information, please see the "Global Effects Fader" section in the Eos Family v2.7.2 Operations Manual.  You can find the manual at the link below.
