Flexi Live Tab to Change What Channels You See
Question
How do I change my channels tab to only look at certain channels?
Why don't I see all of my channels in the Live Channel tab?
Answer
The [Flexi] key on your face panel will let you change what channels you see in your Live tab. To change this, select your Live tab so it is highlighted in yellow then tap the [Flexi] key. Every time you tap that key, you will notice the tab name changes to reflect what you focus on, as well as the top right corner of the tab. You will see only channels that fall under the option you have selected. For example, 'Live Summary Manual' or 'Live Table Manual' only shows channels with manual (red) values applied to them.
You can use Flexi to focus on the following options:
  1. All Channels
  2. Patched Channels
  3. Manual Channels
  4. Show Channels
  5. Active Channels
  6. In Use Channels
  7. Selected Channels
  8. View Channels
