Generic Non Dim Profiles do not work correctly in Eos v3.2.11 or 3.2.12
When patching a new Non Dim fixture in Eos v3.2.11.27 or 3.2.12.1, the channel does not operate correctly and does not display the "ND" NonDim indicator in the tombstone.
Channel Tombstone with NonDim Indicator
Changes to the Eos Fixture Library accidentally changed the profiles for Generic Non Dim.  These profiles should all have two ranges - one range where they are "off" and one where they are "on", without fading in-between.   The incorrect versions have a single range and produce a faded output.
Showfiles created in v3.2.10 and lower will have the correct profiles.  Avoid using the "Update All" option in Patch since this will cause any Non Dims to change to the new (incorrect) range.
The profiles can be recreated in the Fixture Editor with these settings:
Non Dim at 50
Generic Non Dim at 50
Non Dim at Full
Non Dim at Full
Non Dim On at 0
Non Dim On at 0
Non Dim On at 0-50
Non Dim On at 0-50
ETC are working on a Fixture Library Patch to resolve this issue.  It will be released through the Fixture Library Hub
