How Do I Set a Dimming Curve?
Sometimes, you'll want to configure a dimmer to have a specific curve that doesn't normally follow the default dimming curve.
To change the dimming curve, simply follow the steps below:
Steps to Solution
  1. Go into Patch
  2. Select the Channels you want to modify, for example press [1][Enter] to select Chan 1.
  3. Press Soft Key 2 for {Attributes}.
  4. Click on the Box Labeled {Curve}.
  5. From here, you can select from a list of pre-made curves
