How to change which monitor the CIA (Central Information Area) is displayed on Eos Family consoles?
Question
I want to change which monitor the CIA (Central Information Area) is display on my Eos Family console. How do I change this?
Answer
The CIA is always displayed on the monitor designated as Primary. Follow the instructions below to change that setting:
- Exit your showfile to go to the ECU Shell, or stay in the Shell if already there.
- Click on Settings
- If not already on the General tab, click the {General} button in the top right corner.
- Click on the {Monitor Arrangement} button to open that window.
- Click on the monitor you want to make Primary. If you're unsure which letter corresponds to the physical monitors, you can click {Identify} to display the letter on the monitors.
- Check the box next to "Primary", then click {Apply} and {Keep} to save the settings.
- Click {Accept} at the bottom of the Settings
- Click {Primary} to go into your showfile.
On Eos Classic, EosTi, and Gio the Primary is locked to the right touchscreen on the desk. On Gio @5 the Primary is locked to the touchscreen on the desk.
Related Links/References
- Monitor Arrangement in the user manual
- Eos Monitor Arrangement and Touch Screen Configuration
