EXPS Disk Drive not Working
EXPS Disk Drive Not working.
.EXPS Disk Drive Not working, everything else works.
  1. Try another Diskette.
  2. Check Disk Data and Power Cables and seating.
  3. Try an RFU to see if that works. If not it is the Disk/IO IC U25/U36, and check for loose pins.
  4. If not that the disk drive needs to be replaced.
Related Links/References
