About Show in Express consoles
About Show provides you with information about the currently loaded show. It tells you how many channels and dimmers your show is configured for and your utilization of recordable entities such as cues, submasters, groups, focus points, macros and time code events. This is important because not enough memory is available to store the maximum number of all recordable entities at the same time.
Use About Show to monitor your memory usage as the complexity of your show increases. If you fill the available memory, reclaim some of it by clearing recorded entities that you are no longer using, for example by reducing how many channels and dimmers are patched.
Press [About] [Enter] to go to the About Show display.
Label Your show’s name. The show may be named with Expression Off-Line. See Expression Off-Line.
Number of channels Shows the value set in the System Settings menu. See Setting the number of channels.
Number of dimmers Shows the value set in the System Settings menu. See Setting the number of dimmers.
Recorded Shows how many of each item in the first column that have been recorded.
% Memory Shows what percentage of console memory is consumed for each item in the Recorded column.
Remaining Shows how many more of each item in the first column may be recorded before reaching the console maximum.
System setup Shows how much console memory is used for your setup and configuration settings.
Memory left Shows what percentage of console memory is remaining for your show.
