Copying Macros in Express
You may want to copy a macro or use macros as building blocks for new macros.
To copy contents of one macro to another, follow these steps:
Keystrokes: Actions:
1. Press [Setup]. Selects Setup display
2. Press [8], Macro Editing, and press [Enter]. Selects Macro display mode
Prompt reads: Select macro number, then press ENTER
3. Press [S7], More Softkeys, [S5], Copy Macro. Prompt reads:
To copy macro(s), select macro number(s) to copy and press ENTER
To cancel, press CLEAR
4. Press [2].a Prompt reads:
To copy selected macro(s), select target macro and press ENTER To cancel, press CLEAR
5. Press [Enter]. Prompt reads:
6. Press [2][5], the number of the new macro. Corner reads: Macro 25
7. Press [Enter]. Macro copy is complete. The contents of macro 2 have been copied into macro 25
In step 4, you may use [And] and [Thru] to enter multiple macros to copy. If you do, the new macros will be numbered consecutively, starting with the macro you enter in step 6.
