Focus Point List in Express
The Focus Point list shows all the focus points in the show by number and label. The list can be paged if there are more than 54 focus points in the show (18 focus points shown per column). Focus points may be labeled in the Focus Point List or deleted there from the show, either individually or in ranges.
In the Focus Point List display, a selected focus point is identified by a highlighted white row and a selected field is highlighted in yellow.
80 You can label with Expression Off-Line, not the console.
Labeling a focus point
If you have Expression Off Line, follow this procedure to label a focus point in the Focus Point List display.81
Keystrokes: Action:
1. Press [Blind] [Focus Point] [Enter] [S2], Focus List. Displays Focus Point List Prompt reads:
Select focus point number(s)
2. Press [4] [B]. Selects focus point 4 Prompt reads:
Type focus point label (F6=clear to end, F7=previous focus point level, F8=next focus point label)
3. Enter your label, then press [Enter]. Completes labeling of focus point 4
Deleting a focus point
Follow this procedure to delete one or more focus points in the Focus Point List display.
Keystrokes: Action:
2. Press [S6], Delete Focus. Prompt reads:
To delete focus point(s), press number(s) and press ENTER To cancel, press CLEAR
3. Press [4] [And] [5] [Enter] [Enter]. Deletes focus points 4 and 5 Prompt reads:
Select focus point numbers(s)
81 See Expression Off-Line, for more information about this program.
