Modifying Macros in Express
Editing mode
In the Macro mode display, you can edit macros in Insert or Replace modes. In Insert mode, if you highlight a keystroke and type another keystroke, the console inserts the new keystroke before the highlighted one. In Replace mode, if you highlight a keystroke and type another keystroke, the console replaces the highlighted keystroke with the new one.
To switch from Insert mode to Replace mode, press [S2], Replace. To switch from Replace mode to Insert mode, press [S2], Insert. The console indicates the editing mode in the upper left corner of the command display.
Editing keys
[] and [] move the highlight left or right when you are editing a macro. [S3], Delete entry, deletes highlighted keystroke.
