Flickering on ColorSource V Series Fixture After Update
ColorSource V series fixtures function just fine when set to a constant intensity, but attempting to fade them up or down causes all fixtures to flash or jump between intensities in unison.
Explanation of Issue
Fixture Firmware version 4.3.0 introduced a new dimming curve parameter to the Standard and Direct DMX modes on the ColorSource V series fixtures. This parameter was added to the end of the pre-existing profiles, so their DMX footprints increased by 1 address.  As a result, fixtures that are addressed sequentially can end up with overlapping ranges, so that the address being used for intensity on one fixture is also controlling curve on the previous fixture.
Current fixture libraries on all of our consoles have been updated to reflect this change, but, if you're using up-to-date fixtures with an older console library, you may end up with an overlap in your fixtures' address ranges. There are 2 options that ETC recommends to resolve the issue.
Option 1: Update Controller's Fixture Library
  1. To gain access to all the new features your fixture has to offer, follow the appropriate instructions below to update your console's library.
    1. How to Update the Eos Family Fixture Library
    2. How To Update the Fixture Library on ColorSource Consoles
    3. How To Update the Fixture Library on EchoTouch
  2. If you had previously patched the fixtures into your showfile, existing channels will NOT be automatically updated to the new profile version.
    1. For ColorSource and EchoTouch, you'll need to remove the channels and re-patch them.
    2. For Eos Family consoles, you can either re-patch your channels or follow the instructions in this article: How to Update Fixture Profiles for Patched Channels
Option 2: Offset Addresses
If updating isn't an option with your production schedule, you can adjust the  patch instead.
You will only run into problems with this issue if your fixtures are addressed sequentially with no gaps between them. You can correct for the overlap by increasing the start address by 1 for every fixture except the first in the address range. This should result in a single address gap between all of your fixtures. This will need to be changed both on the fixtures and at the console or controller.
Patch Example without Offset:
Patch Example with Offset
Patch Example with Offset:
