Appropriate Gobo Size for Relevé Spot
XDLT Lenses are for LED use only! Please click here for more information.
Lens Degree Pattern Holder Lens Type Model Number Part Number Color Frame / Doughnut Size
90 Degree A or B
Standard 490LT 7060A2052-K 7.5" x 7.5" (190mm)
70 Degree Standard 470LT 7060A2051-K 7.5" x 7.5" (190mm)
XDLT XDLT70 7462A2009-K 7.5" x 7.5" (190mm)
50 Degree Standard 450LT 7060A2005-K
7060A2205-K
6.25" x 6.25" (159mm)
EDLT 450EDLT 7060A2049 6.25" x 6.25" (159mm)
LED EDLT LED50LT 7460A2008 7.5" x 7.5" (190mm)
XDLT XDLT50 7462A2008-K 7.5" x 7.5" (190mm)
36 Degree Standard 436LT 7060A2004-K
7060A2204-K
EDLT 436EDLT 7060A2048 6.25" x 6.25" (159mm)
XDLT XDLT36 7462A2007-K 7.5" x 7.5" (190mm)
26 Degree Standard 426LT 7060A2003-K
7060A2203-K
EDLT 426EDLT 7060A2047 6.25" x 6.25" (159mm)
XDLT XDLT26 7462A2006-K 7.5" x 7.5" (190mm)
19 Degree Standard 419LT 7060A2002-K
7060A2202-K
EDLT 419EDLT 7060A2046 6.25" x 6.25" (159mm)
XDLT XDLT19 7462A2005-K 10" x 10" (254mm)
14 Degree Standard 414LT 7060A2050-K 7.5" x 7.5" (190mm)
XDLT XDLT14 7462A2004-K 10" x 10" (254mm)
10 Degree Standard 410LT 7060A2001-K 12" x 12" (305mm)
XDLT XDLT10 7462A2003-K 14" x 14" (356mm)
5 Degree Standard 405LT 7060A2000-K 14" x 14" (356mm)
XDLT XDLT5 7462A2002-K 17.5" x 17.5" (444.5mm)
Zoom Lens Color Frame / Doughnut Size
15-30 Degree 7.5" x 7.5" (190mm)
25-50 Degree
Fixture Type Pattern Holder Color Frame / Doughnut Size
Source Four Jr. and Jr. Zoom M 6.25" x 6.25" (159mm)
Source Four PAR and MultiPAR None 7.5" x 7.5" (190mm)
Source Four Mini and Mini LED E 2.75" x 2.75" (70mm)
ColorSource Spot jr. M 5.45" x 5.45" (138mm)
Relevé Spot 1.79" (45.5mm) diameter None
