Relevé Spot Error Codes
Error Description Fix
Calibration Idle No Calibration in progress Should not appear in normal circumstances
In Progress... Calibration is running
Calibration Complete Calibration completed successfully; correction threshold number should appear on-screen
Canceled by User Calibration terminated via UI Input
Initial Alignment Err Error during initial motor alignment; motor or encoder (or both) are not moving
  • Check that Pan and Tilt locks are disengaged
  • Make sure Pan and Tilt can move freely of obstructions
  • If issues persist, check belt in enclosure to encoder and check for freedom of movement
No Stop on Pass 0 Did not find end-stop (based on encoder input) during initial movement
No Stop on Pass 1 Did not find end-stop (based on encoder input) during first movement
No Stop on Pass 2 Did not find end-stop (based on encoder input) during second movement
No Encoder Response Encoder not changing when moving away from end-stop at the start of a calibration pass
  • Check wiring connections at the Pan/Tilt Motor Driver board and the encoder
  • Replace Motor Driver PCB
  • Replace Encoder Board
Range Error (High) Too many encoder counts detected during calibration pass
  • Re-try the calibration process
Range Error (Low) Too few encoder counts detected during calibration pass
Internal Error Problem communicating with the Pan/Tilt motor driver board
