Source Four PAR Safety Cable
We highly recommend that all UL listed Source Four fixtures are secured with a safety cable, for which the ETC part number is 7060A1022.
This cable is a 30" long 1/8" diameter black wire rope cable with snap clamp fitted.
The safety ratio of the cable is 5:1
The breaking load of the cable is 2000lb.
The rated Safe Working Load (SWL) of the cable is 400lbs.
Disclaimer: The ETC Safety cable P/N 7060A1022, is to be used as a safety device for ETC lighting fixtures only.  It should not be used for rigging or lifting any items or people and should not be used under tension.
