Source 4 LED Series 3 Software Version History
Filter:
Version Release Date Key Enhancements Software Download
1.4.1 Apr 9th, 2026 New Features:
Release Note
1.4.0 Nov 6, 2025 New Features:
  • 16-bit DMX modes: 16-bit modes provide greater resolution but require more channels
  • More options for 1 Ch DMX mode: Use 1 Ch mode to provide 1-channel intensity control for a gel color, preset, or studio preset
  • More Curve channel options: New Quick Linear and Unregulated options for the Curve channel
  • Focus mode adds tilt control: Set a target tilt value, and then view the real-time Current Tilt display as you adjust the fixture tilt in Focus mode
  • Radio connection status: New Con value shows current radio connection status when using Multiverse® wireless control
  • Additional flicker control option: New PWM setting of Medium (11 kHz) joins the original High (25 kHz) and Low (5 kHz) settings
Fixes:
  • DMX snapshot: Capture the current DMX look to a preset when in one of five DMX modes  (3 Ch RGB, Studio, Expanded, Studio 16bit, and Expanded 16bit)
Release Note
Software
1.3.0 Nov 27th, 2023 New Features:
  • HSIC DMX mode
  • Quick dimming curve
Release Note
Software
1.2.0 Sept 29, 2022 New Features:
  • Stand-alone Gel mode
  • Multiverse enhancements, including wireless strength and quality display
  • Direct mode is now the default DMX mode
  • Function button now displays a list of modes to choose from, rather than requiring you to toggle through the mode screens individually
  • Control priority for the fixture now follows a "last takes precedence" rule, with wired DMX taking precedence over wireless DMX when both are present
Release Note
Software
1.1.2 Mar 3, 2022 New Features:
  • Hardware Support
  • Changes to the dimming curve in 25 kHz mode to improve color stability at low dimming levels
Release Note
Software
1.1.0 Sept 2, 2021 Fixes:
  • Bug fix in dimming engine
  • Updates to Direct mode calibration data
Release Notes
Software
1.0.0 Mar 11, 2021 Initial Product Release Release Note
