Cable Cross Database now says my cable is not approved
"I thought a cable was approved for Paradigm/Echo and now it is no longer approved. When did this change?"
Cable manufacturers may change cable specifications at any time, which is outside of ETC's control. Questions about whether an unlisted cable is approved for use should be directed to Applications Engineering.
In the Summer of 2020, a number of cables for Paradigm/Echo changed status from Approved to Not Approved after a review found that some specs did not meet the criteria for compatibility in 100% of installations. This does not mean that any already installed cables will cease to function, but rather that they may not have functioned correctly in the first place. For example, this is more likely to be a concern for long cable runs than for short ones, since meeting the specs helps ensure signal integrity across the maximum run length.
If a site is experiencing station communications issues across cable that was previously approved, contact ETC Technical Services for assistance.
List of cables that status changed to unapproved in Summer 2020:
PARADIGM/ECHO
Belden 1314SB
Belden 5100UE
Belden 5200UE
Belden 5240U1
Belden 6100UE
Belden 6200UE
Cerco Cable 8190
Comtran Corporation 2836
Comtran Corporation 32836
Connect-Air W161P-1047
Wattstopper OEM HDLW2P
West Penn Wire (CDT) 225
West Penn Wire (CDT) 226
West Penn Wire (CDT) 227
West Penn Wire (CDT) 25226B
West Penn Wire (CDT) AQ227
Windy City Wire (SmartWire) 001360
Windy City Wire (SmartWire) 001361
Windy City Wire (SmartWire) 028100
Windy City Wire (SmartWire) 104500
Windy City Wire (SmartWire) 104580-S
Windy City Wire (SmartWire) 16-02P-BLK
Windy City Wire (SmartWire) 1602-GRY
Windy City Wire (SmartWire) 428109
Windy City Wire (SmartWire) 428109-S
Windy City Wire (SmartWire) 428110-110
Windy City Wire (SmartWire) 8160265
Windy City Wire (SmartWire) 991360-110BR
Windy City Wire (SmartWire) 991360BR
