LED Fixture Color Calibration and Matching
Overview
This article explains how LED binning and calibration work in ETC luminaires, what happens when colors fall outside a fixture’s calibrated color gamut, and why certain operating modes are not expected to visually match. It also provides practical steps users can take to verify behavior and improve color matching in real-world applications.
LED Binning: Why Individual Emitters Are Never Identical
LEDs are manufactured on crystalline semiconductor wafers, and small variations in the crystal structures result in slight differences in wavelength and output between individual LED chips. To manage this, LED manufacturers measure each chip and group them into wavelength and output “bins.” Even within a single bin, the allowable variation is large enough to be visible to the human eye.
For entertainment lighting, this variation is critical. ETC minimizes differences by carefully selecting LED bins, but supply constraints and manufacturing realities mean fixtures cannot rely on perfectly identical emitters. As a result, raw, single-emitter output is inherently variable from unit to unit.
Calibration: How Fixtures Are Matched Despite Bin Variation
To overcome bin-to-bin and within-bin variation, ETC calibrates every luminaire at the factory. During calibration, the output and wavelength of each emitter are measured and stored in the fixture. When a calibrated color is requested, the fixture computes a custom mix of its own emitters to hit the defined target color.
As long as the requested color lies within the fixture’s calibrated color space, different luminaires—even with different underlying LEDs—can produce the same perceived color.
Color Gamut and What “Out of Gamut” Means
A fixture’s color gamut is the full range of colors it can physically produce. Calibrated control modes (such as RGB or HSI) operate within a defined, standardized color space that is shared across ETC luminaires.
When a requested color falls inside both the standardized color space and the fixture’s physical gamut, calibration can compensate for LED differences and matching is expected. When the requested color lies outside the fixture’s gamut—most commonly at highly saturated extremes like deep blue, full red, or full green—the fixture cannot reproduce the exact target. In these cases, it produces the closest achievable color.
Once a color is out of gamut, calibration can no longer guarantee a match between fixtures. Differences in LED wavelength that are normally hidden by calibration become visible.
Example: RGB Color Space vs Fixture Gamut
The diagram below conceptually illustrates this relationship:
- The outer triangle represents the standardized RGB color space used by calibrated control modes.
- The inner, irregular shape represents the physical color gamut of a specific luminaire.
- Colors that fall inside both shapes are in gamut and can be accurately calibrated and matched.
- Colors that fall inside the RGB space but outside the fixture gamut are out of gamut; the fixture must approximate the closest possible color, and matching is no longer guaranteed.
Direct Mode: What to Expect
In Direct mode, users control individual emitters directly. While many ETC fixtures still correct for flux differences, Direct mode cannot correct for wavelength differences between LEDs. Correcting for wavelength differences would require the fixture to turn on other LED colors that the user may not want turned on. As a result, two fixtures driven with only a single emitter (for example, Blue at 100%) are not expected to match exactly.
Practical Steps to Verify and Improve Color Matching
Users can take several practical steps to confirm expected behavior and improve matching:
- Verify the Control Mode - Ensure fixtures are operating in a calibrated mode (RGB, HSI, or equivalent) when evaluating color matching. Direct mode should only be used when intentional raw emitter control is required, such as when the mix of emitters used is more important than an exact color match
- Compare Using a built-in White Preset - Use a built-in calibrated white preset—such as 3200K (often Preset 1)—to compare fixtures. These presets rely directly on each fixture’s calibration data to produce a known white point and are an excellent test of overall calibration performance. Fixtures that match well at a calibrated white are generally performing correctly.
- Check for Out-of-Gamut Colors - If a color does not match, reduce saturation slightly. Extremely saturated colors—especially deep blues—are common out-of-gamut cases. Mixing in a small amount of additional emitters can pull the requested color back inside the shared gamut. For example, adding modest Red and Green content to a Blue-heavy mix can dramatically improve matching once the color becomes inside the gamut of all fixtures.
- Avoid Single-Emitter Comparisons - Do not use single-emitter output (for example, Blue-only) as a color consistency test. Such tests intentionally expose LED binning differences and are not representative of calibrated operation.
