Updating ACN/DMX Gateway In Net2 Mode Only (Missing ACN Image)
Having issues updating ACN/DMX gateway that is in Net2 mode only (Missing ACN image) to the latest software.
Having issues updating ACN/DMX gateway Net2 mode only (Missing ACN image) to the latest software.
- Make sure UpdaterAtor, Concert and GCE are closed
- Ensure that a valid default gateway is set for the network interface you are using.
- If running NCE on an ETC console, make sure the DHCP server is disabled.
- Open NCE and enable Network Address Server
- Navigate the menu on the unit using the front soft key to the Download Software page and Hold the button for 5 seconds
- The latest software (in Nodesbin) will start to downloading and installing (6.0.1 is the last version that will allow you to switch to Net2 mode)
