Does The 0-10v Gateway Do DMX Out/Thru
I need another DMX thru port, but I only have a Response 0-10v gateway. Will the DMX In on the gateway also work as a DMX Out or Thru?
Description
No, the DMX will not work as an Out; however, the Response 0-10v gateway's DMX port does have a thru.  Pins 4, 5, and 6 are a passive thru from DMX.
Pin 4 Common thru
Pin 5 Data - thru
Pin 6 Data + thru
