How do I set the Custom dimming curve in 0-10v Response Gateway?
In the Response 0-10v Gateway, there is a dimming curve called "Custom".
Setting the Dimmer Curve into this mode will function the same as "Linear" if no Custom Curve has been defined or if the 0-10V Gateway is running a software version prior to 3.0.0
The custom curve is defined using the Custom Curve Editor as a part of the 0-10V Gateway Version 3.0.0 or newer Device Package for Concert version 4.0.2 or greater.
In Concert:
