ELV Module Fault Indicator
ELV modules have a fault indicator that will indicate one of two things: circuit overcurrent or circuit overvoltage. Inrush current can cause an overcurrent fault state without tripping the breaker. You may also see the fault indicator if you have inductive load (i.e. a magnetic transformer driver) on the circuit, which can cause a spike in voltage.
