Module Information Summary
This summary provides module information broken down by market and application.
Four major market groups are used to separate modules:
  • UL market - ETC Americas, 120V-60Hz power, Sensor and Unison products
  • CE market - ETC Europe, 230V 50Hz power, Sensor CE and Unison products
  • Hi-voltage (Asian) market - ETC Asia, 240V 50 or 60 Hz power, Sensor "HSR" products
  • Delta (Cruise ship) market - ETC Europe/Americas, Delta (no Neutral) 120/230V 50/60Hz, Sensor and Unison Delta products
UL Market dimmer modules
Model #
Part Number
Module Description
Risetime
Voltage
L10 7050A1081 10A Low Wattage Dimmer
120V
L10F 7050A1082 10A Low Wattage 3-Wire Fluorescent Dimmer
120V
D15 7050A1001 Dual 1.8kW Dimmer
350µs
120V
D15AF 7050A1002 Dual 1.8kW Advanced Features (AF) Dimmer
500µs
120V
D15BC
7050A1010 Dual 1.8kW 15A Branch Circuit Breaker
0s
120V
D15CC 7050A1011 Dual 2.4kW 15A Constant Circuit
0s
120V
D15E 7050A1030 Dual 1.8kW Enhanced Dimmer
500µs
120V
D15C 7050A1060 Dual 1.8kW Module Fused (Chicago)
120V
D15FB 7183A1073 EM Fluorescent Constant Module
120V
D15F 7050A1042 Single 1.8kW (3 Wire Fluorescent) Dimmer
0s
120V
D15FC 7050A1061 Single 1.8kW Fluorescent Module Fused
120V
D20 7050A1003 Dual 2.4kW Dimmer
350µs
120V
D20AF 7050A1004 Dual 2.4kW AF Dimmer
500µs
120V
D20BC 7050A1012 Dual 2.4kW 20A Branch Circuit Breaker
0s
120V
D20CC 7050A1013 Dual 2.4kW Constant 20A Circuit
0s
120V
D20DHR 7050A1080 Dual 2.4kW Dimmer
800µs
120V
D20E 7050A1031 Dual 2.4kW Enhanced Dimmer
500µs
120v
D20F 7050A1006 Single 2.4kW (3 wire Fluorescent) Dimmer
0s
120V
D20FB 7183A1074 EM Fluorescent Constant Module
D20HR 7050A1005 Single 2.4kW High Risetime Dimmer
800µs
120V
ELV10 7183A1017 Dual 1.2kW Reverse Phase Module
120V
AELV5 7183A1028 Dual 1.4kW Reverse Phase Module
D50AF 7050A1007 Single 6kW Dimmer
500µs
120V
D50AFG 7050A1071 6kW Single GFI Module
500µs
120V
D50AFN 7050A1070 6kW Single Neutral Disconnect Module
500µs
120V
D50HR 7050A1008 6kW Single High Risetime Dimmer
800µs
120V
D50CC 7050A1022 Single 6kW Constant 50A Circuit
0s
120V
D50HR
7050A1008
Single 6kW High Risetime Dimmer (2-Slot Module)
800µs
120V
D100AF 7050A1009 Single 12kW Dimmer (2-Slot Module)
500µs
120V
R15AF 7050A1074 Dual 1.8kW AF Relay
0s
230V
R20AF 7050A1073 Dual 2.4kW AF Relay
0s
230V
D20J
7050A1088 Dual 2.5kW
350µs
100V
D20JE 7050A1090 Dual 2.4kW
100V
D20SW 7030A1002 Dual 2.4kW Sinewave
100V
D15AFG 7050A1067 Dual 1.8kW GFI AF Dimmer
500µs
120V
D15AFN 7050A1066 Dual 1.8kW Neutral Connect AF Dimmer
500µs
120V
D20AFG 7050A1069 Dual 2.4kW GFI AF Dimmer
500µs
120V
D20AFN 7050A1068 Dual 2.4kW Neutral Connect AF Dimmer
500µs
120V
D20AFJ 7050A1075 Dual 2.4kW 30mA DCS AF Dimmer (Japanese RCD)
500µs
100V
**Not tested at 100,000 AIC, but similar in design to modules which have passed UL 100,000 AIC certification
High Voltage (H) Market Modules
All High Voltage modules are installed only in Sensor "H" series racks. These racks are intended for the Asian market area where supply voltage is 230v but CE requirements do not apply.
Model #
Part Number
Module Description
Risetime
Voltage
HD15 7050A1045 Dual 3kW Dimmer
225µs
230V
HD15AF 7050A1046 Dual 3kW AF Dimmer
350µs
230V
HD15F 7183A1056 Single 15A Fluorescent Module
230V
HD25 7050A1047 Dual 5kW Dimmer
225µs
230V
HD25AF 7050A1043 Dual 5kW AF Dimmer
350µs
230V
HD25F 7050A1051 Single 25A Fluorescent Module
230V
HD50AF 7050A1048 Single 10kW AF Dimmer
350µs
230V
HELV10 7183A1017 Dual 1.2kW Reverse Phase Module
230V
HELV5 7183A1055 Dual 5A Reverse Phase Module
CE Market Modules
Model #
Part Number
Module Description
Risetime
Voltage
ECC15
7070A1046
Dual 3kW 15A Constant Circuit
0s
230V
ECC25
7070A1047
Dual 5kW 20A Constant Circuit
0s
230V
ED15
7070A1002
Dual 3kW Dimmer
225µs
230V
ED15AF
7070A1003
Dual 3kW AF Dimmer
400µs
230V
ED15AFN
7070A1029
Dual 3.0kW ND AF Dimmer
400µs
230V
ED15AFR
7070A1030
Dual 3.0kW Residual Current Disconnect (RCD) AF Dimmer
400µs
230V
ED15AFRF
7070A1064
3kW Florescent Dimmer Residual Current Disconnect (RCD)
400µs
230V
ED15AFS
7070A1004
Dual 3kW AF Dimmer (Obsolete)
225µs
230V
ED15AFE
7070A1063
RED 3kW
100µs
230V
ED15E
7070A1032
Dual 5kW Dimmer (Unison)
400µs
230V
ED15N
7070A1028
Dual 3.0kW Neutral Disconnect (ND) Dimmer
225µs
230V
ED15NE
7083A1042
3kW Neutral Disconnect Dual Module
400µs
230V
ED15RE
7083A1046
3kW Residual Current Disconnect (RCD) Dual Module
400µs
230V
ED15RS
7083A1045
225µs
230V
ED15S
7070A1035
Single 5kW Dimmer (Obsolete)
225µs
230V
ED25
7070A1007
Dual 5kW Dimmer
225µs
230V
ED25AF
7070A1003
Dual 5kW AF Dimmer
350µs
230V
ED25AFN
7070A1032
Dual 5.0kW ND AF Dimmer
350µs
230V
ED25AFR
7070A1033
Dual 5.0kW RCD ND AF Dimmer
350µs
230V
ED25AFRF
7070A1065
5.0kW Fluorescent Dimmable RCD
350µs
230V
ED25AFS
7070A1009
Dual 5kW Sense
250µs
230V
ED25AFS
7070A1004
Dual 5kW AF Dimmer (Obsolete)
225µs
230V
ED25E
7070A1034
Single 5kW Dimmer
350µs
230V
ED25HR
7070A1027
Single 5kW AF High Risetime Dimmer
650µs
230V
ED25HRR
7070A1034
Single 5.0kW RCD AF High Risetime Dimmer
650µs
230V
ED25N
7070A1035
Dual 3.0kW ND Dimmer
225µs
230V
ED25NE
7083A1044
5kW Single Dimmer Neutral Disconnect
600µs
230V
ED25NS
7083A1043
400µs
230V
ED25RE
7083A1048
5kW Single Dimmer Residual Current Disconnect (RCD)
600µs
230V
ED25RS
7083A1047
400µs
230V
ED25S
7083A1033
5k Single Dimmer
400µs
230V
ED25S
7070A1033
225µs
230V
ED50AF
7070A1013
350µs
230V
ED50AFR
7070A1035
Single 10.0kW RCD ND AF Dimmer
350µs
230V
ED50AFS
7070A1015
Single 10kW AF Dimmer (Obsolete)
225µs
230V
ER15AF
7070A1048
Dual 5kW AF Relay
0s
230V
ER25AF
7070A1049
Dual 3kW AF Relay
0s
230V
CDC
7070A1049
Dual 3kW AF Relay
0s
230V
Modules with the "S" suffix on the model number are an obsolete Unison module. Information is included for reference only.
