Not All Firing Modes Function with ELV10 in a Sensor+ Rack
In CEM+ v3.0.0 and higher, you can use ELV10 (Electronic Low Voltage) modules in Sensor + racks, but only in Normal (Forward Phase) and Reverse Phase modes.
The following firing modes can be selected, but are not functional when using ELV10 modules:
  • Switched
  • Non-Dim
  • Always On
  • Fluorescent
  • Dimmer Doubling
Any version of CEM+ software between 3.0.0 and 3.1.3 will have this problem, and earlier software versions do not support ELV10. No further updates are planned.
Related Links/References
