Sensor Module Information Summary
Module Decoder
E TR 25 S AF R X
- The number refers to amperage
- The letters directly before the number tells you the module dimming type
- The inclusion of AF means the module is capable of Advanced Features
- The letter that can be before the module type depicts if the module is meant for European (E), Hong Kong (H), or 277V (A) markets
- After "AF" there may be another letter (or combination of letters) that determine several miscellaneous factors about the modules:
- E: Enhanced 500 µs risetime
- HR: "High Risetime," 1000µs
- DHR: Dual High Risetime, 800µs
- C: Fused for Chicago code requirements
- F: 3-Wire Fluorescent
- FB: 2-Wire Fluorescent + Battery Charge Circuit
- G: Ground Fault Interrupt
- N: Neutral Disconnect (Europe) or Neutral Bus without ND (Japan)
- R: RCD (Residual Current Disconnect)
- If there is a J at the end of the module model number- that module is meant for the 100V Japanese market
Four major market groups are used to separate modules:
- UL market - ETC Americas, 120V, 60 Hz
- UL market - Japan, 100V, 50 or 60 Hz, "-J"
- UL market - ETC Asia (Hong Kong), 240V, 50 or 60 Hz, Sensor "HSR" products
- CE market - ETC Europe, 230V, 50 Hz, Sensor CE
UL 120V Modules
Model # |
Part Number |
Module Description |
Risetime |
Voltage |
| L10 | 7050A1081 | 10A Low Wattage Dimmer |
n/a |
120V |
| L10F | 7050A1082 | 10A Low Wattage 3-Wire Fluorescent Dimmer |
n/a |
120V |
| D15 | 7050A1001 | Dual 1.8kW Dimmer |
350µs |
120V |
| D15AF | 7050A1002 | Dual 1.8kW Advanced Features (AF) Dimmer |
500µs |
120V |
BC15 |
7050A1010 | Dual 1.8kW 15A Branch Circuit Breaker |
n/a |
120V |
| CC15 | 7050A1011 | Dual 2.4kW 15A Constant Circuit |
n/a |
120V |
| D15E | 7050A1030 | Dual 1.8kW Enhanced Dimmer |
500µs |
120V |
| D15C | 7050A1060 | Dual 1.8kW Module Fused (Chicago) |
n/a |
120V |
| D15FB | 7183A1073 | Single 1.8kW 2-Wire Fluorescent with Battery Circuit Dimmer |
n/a |
120V |
| D15F | 7050A1042 | Single 1.8kW (3 Wire Fluorescent) Dimmer |
n/a |
120V |
| D15FC | 7050A1061 | Single 1.8kW Fluorescent Module Fused |
n/a |
120V |
| D20 | 7050A1003 | Dual 2.4kW Dimmer |
350µs |
120V |
| D20AF | 7050A1004 | Dual 2.4kW AF Dimmer |
500µs |
120V |
BC20 |
7050A1012 | Dual 2.4kW 20A Branch Circuit Breaker |
n/a |
120V |
| CC20 | 7050A1013 | Dual 2.4kW Constant 20A Circuit |
n/a |
120V |
| D20DHR | 7050A1080 | Dual 2.4kW High-Risetime Dimmer |
800µs |
120V |
| D20E | 7050A1031 | Dual 2.4kW Enhanced-Risetime Dimmer |
500µs |
120v |
| D20F | 7050A1006 | Single 2.4kW (3 wire Fluorescent) Dimmer |
n/a |
120V |
| D20FB | 7183A1074 | Single 2.4kW 2-Wire Fluorescent with Battery Circuit Dimmer |
n/a |
| D20HR | 7050A1005 | Single 2.4kW High Risetime Dimmer |
1000µs |
120V |
| ELV10 | 7183A1017 | Dual 1.2kW Reverse Phase Module |
n/a |
120V |
| D50AF | 7050A1007 | Single 6kW Dimmer |
500µs |
120V |
| D50AFG | 7050A1071 | 6kW Single GFI Module |
500µs |
120V |
| D50AFN | 7050A1070 | 6kW Single Neutral Disconnect Module |
500µs |
120V |
| D50HR | 7050A1008 | 6kW Single High Risetime Dimmer |
800µs |
120V |
| CC50 | 7050A1022 | Single 6kW Constant 50A Circuit |
0s |
120V |
| D50HR |
7050A1008 |
Single 6kW High Risetime Dimmer (2-Slot Module) |
800µs |
120V |
| D100AF | 7050A1009 | Single 12kW Dimmer (2-Slot Module) |
500µs |
120V |
| R15AF | 7050A1084 | Dual 1.8kW AF Relay |
0s |
120V |
| R20AF | 7050A1085 | Dual 2.4kW AF Relay |
0s |
120V |
| D20SW † | 7030A1002 | Dual 2.4kW Sinewave |
n/a |
100V |
| D15AFG | 7050A1067 | Dual 1.8kW GFI AF Dimmer |
500µs |
120V |
| D15AFN | 7050A1066 | Dual 1.8kW Neutral Bus AF Dimmer |
500µs |
120V |
| D20AFG | 7050A1069 | Dual 2.4kW GFI AF Dimmer |
500µs |
120V |
| D20AFN | 7050A1068 | Dual 2.4kW Neutral Bus AF Dimmer |
500µs |
120V |
**Not tested at 100,000 AIC, but similar in design to modules which have passed UL 100,000 AIC certification
† Sinewave modules can only be used with Sinewave racks.
UL 100V Modules (J)
Model # |
Part Number |
Risetime |
Voltage |
D20J |
7050A1088 | Dual 2.5kW |
350µs |
100V |
| D20JE | 7050A1090 | Dual 2.4kW |
500 μs |
100V |
| D20AFJ | 7050A1075 | Dual 2.4kW 30mA DCS AF Dimmer (Japanese RCD) |
500µs |
100V |
500µs |
120V |
BC15 |
0s |
120V |
0s |
120V |
UL 240V Modules (H)
All High Voltage modules are installed only in Sensor "H" series racks. These racks are intended for the Asian market area where supply voltage is 230v but CE requirements do not apply.
Model # |
Part Number |
Risetime |
Voltage |
| HD15 | 7050A1045 | Dual 3kW Dimmer |
225µs |
230V |
| HD15AF | 7050A1046 | Dual 3kW AF Dimmer |
350µs |
230V |
| HD15F | 7183A1056 | Single 15A Fluorescent Module |
230V |
| HD25 | 7050A1047 | Dual 5kW Dimmer |
225µs |
230V |
| HD25AF | 7050A1043 | Dual 5kW AF Dimmer |
350µs |
230V |
| HD25F | 7050A1051 | Single 25A Fluorescent Module |
230V |
| HD50AF | 7050A1048 | Single 10kW AF Dimmer |
350µs |
230V |
| HELV10 | 7183A1017 | Dual 1.2kW Reverse Phase Module |
230V |
| HELV5 | 7183A1055 | Dual 5A Reverse Phase Module |
CE 230V Modules
Model # |
Part Number |
Risetime |
Voltage |
ECC15 |
7070A1046 |
Dual 3kW 15A Constant Circuit |
0s |
230V |
ECC25 |
7070A1047 |
Dual 5kW 20A Constant Circuit |
0s |
230V |
ED15 |
7070A1002 |
Dual 3kW Dimmer |
225µs |
230V |
ED15AF |
7070A1003 |
400µs |
230V |
ED15AFN |
7070A1029 |
Dual 3.0kW ND AF Dimmer |
400µs |
230V |
ED15AFR |
7070A1030 |
Dual 3.0kW Residual Current Disconnect (RCD) AF Dimmer |
400µs |
230V |
ED15AFRF |
7070A1064 |
3kW Florescent Dimmer Residual Current Disconnect (RCD) |
400µs |
230V |
ED15AFS |
7070A1004 |
Dual 3kW AF Dimmer (Obsolete) |
225µs |
230V |
ED15AFE |
7070A1063 |
RED 3kW |
100µs |
230V |
ED15E |
7070A1032 |
Dual 5kW Dimmer (Unison) |
400µs |
230V |
ED15N |
7070A1028 |
Dual 3.0kW Neutral Disconnect (ND) Dimmer |
225µs |
230V |
ED15NE |
7083A1042 |
3kW Neutral Disconnect Dual Module |
400µs |
230V |
ED15RE |
7083A1046 |
3kW Residual Current Disconnect (RCD) Dual Module |
400µs |
230V |
ED15RS |
7083A1045 |
225µs |
230V |
ED15S |
7070A1035 |
Single 5kW Dimmer (Obsolete) |
225µs |
230V |
ED25 |
7070A1007 |
Dual 5kW Dimmer |
225µs |
230V |
ED25AF |
7070A1003 |
350µs |
230V |
ED25AFN |
7070A1032 |
Dual 5.0kW ND AF Dimmer |
350µs |
230V |
ED25AFR |
7070A1033 |
Dual 5.0kW RCD ND AF Dimmer |
350µs |
230V |
ED25AFRF |
7070A1065 |
5.0kW Fluorescent Dimmable RCD |
350µs |
230V |
ED25AFS |
7070A1009 |
Dual 5kW Sense |
250µs |
230V |
ED25AFS |
7070A1004 |
Dual 5kW AF Dimmer (Obsolete) |
225µs |
230V |
ED25E |
7070A1034 |
Single 5kW Dimmer |
350µs |
230V |
ED25HR |
7070A1027 |
Single 5kW AF High Risetime Dimmer |
650µs |
230V |
ED25HRR |
7070A1034 |
Single 5.0kW RCD AF High Risetime Dimmer |
650µs |
230V |
ED25N |
7070A1035 |
Dual 3.0kW ND Dimmer |
225µs |
230V |
ED25NE |
7083A1044 |
5kW Single Dimmer Neutral Disconnect |
600µs |
230V |
ED25NS |
7083A1043 |
400µs |
230V |
ED25RE |
7083A1048 |
5kW Single Dimmer Residual Current Disconnect (RCD) |
600µs |
230V |
ED25RS |
7083A1047 |
400µs |
230V |
ED25S |
7083A1033 |
5k Single Dimmer |
400µs |
230V |
ED25S |
7070A1033 |
225µs |
230V |
ED50AF |
7070A1013 |
350µs |
230V |
ED50AFR |
7070A1035 |
Single 10.0kW RCD ND AF Dimmer |
350µs |
230V |
ED50AFS |
7070A1015 |
Single 10kW AF Dimmer (Obsolete) |
225µs |
230V |
ER15AF |
7070A1048 |
Dual 5kW AF Relay |
0s |
230V |
ER25AF |
7070A1049 |
Dual 3kW AF Relay |
0s |
230V |
CDC |
7070A1049 |
Dual 3kW AF Relay |
0s |
230V |
Modules with the "S" suffix on the model number are an obsolete Unison module. Information is included for reference only.
