Changing the Fuse in a SmartModule 2
The user interface on my SmartModule 2 is not powering on.
Explanation of Issue
This is most often caused by a blown fuse. This fuse requires skill with thru-hole soldering to change; if you're not comfortable working with a soldering iron, it's best to contact your local ETC dealer to either set up a repair with ETC or have a technician perform the repair in the field.
Ensure all power has been disconnected from equipment before servicing. The information in this article is provided to assist in troubleshooting. Perform work at your own risk. If you do not feel comfortable performing the work, please contact ETC Technical Services or an authorized service provider. Be aware that ETC and its Affiliates are not responsible for any damage or injury caused by service of our products by anyone other than us or our authorized service providers, and such damage is excluded from the product’s warranty. |
Required tools and materials:
- Soldering iron
- Solder (ETC recommends using lead-free solder)
- Solder wick — recommended, but not required. Helps remove the existing solder to make it easier to remove the fuse.
- Replacement fuse — ETC part number F172-F. This can be ordered from an ETC dealer; if you prefer to purchase one elsewhere, it is a 0.152A, 250V PICO fast-blow PCB fuse.
| 1. Remove the 3 screws on each side of the back of the module, then pull the back out and move it to the bottom of the unit. This will expose the power supply. | ![]() |
| 2. Remove the four nuts and move the control and phase wires out of the way. Ensure you make note of where they connect. | ![]() |
| 3. De-solder each end of the fuse and remove it from the PCB. | ![]() |
- Place the new fuse, soldering it in place on each end.
- Re-attach the wires to the power supply.
- Re-attach the cover to the back of the SmartModule.
- Apply power and test whether the UI powers back up. If the issue persists, contact ETC technical services for assistance.
