Recording SmartLink Presets from SmartPack or SmartSwitch
There are two options for recording a preset to a SmartLink station for a SmartPack or SmartSwitch:
  • Record the preset at the SmartPack/SmartSwitch user interface via the on-screen menu
  • Record the preset at the preset station via remote record
To record from the processor UI:
  • Set the desired levels for the circuits in the rack
  • Navigate to Presets -> Record Preset -> Number and choose to record
To record from the station
  • Make sure that Remote Record is enabled at the processor
    • Stations -> Remote Record -> Enable
  • Make sure that Station Master is enabled at the processor
    • Stations -> Station Master -> Enable
    • If this is a multi-rack system, only one rack should have Station Master enabled, and it should be one with a station power supply
  • Set the desired levels for the circuit in the rack
  • At the station, press and hold the desired button until it flashes green 3 times
The SmartPack User Manual and SmartSwitch User Manual also walk through these options and can be referenced if needed.
