SmartPack Overview
SmartPacks are designed to provide SCR-based, professional quality dimming packaged for portable, touring and permanent installations. ETC offers three versions of the SmartPack including the SmartPack 19” Portable Pack, SmartPack Touring Systems, and the SmartPack Wall Mount unit.
Standard Features
  • DMX512 native
  • SmartLink® enabled for pack to pack synchronization.
  • Thirty-two programmable presets and a built-in sequencer for stand-alone operation.
  • Ultra-quiet variable speed cooling fan.
  • Multi-language user interface including English, Spanish, German, and French.
  • User selectable dimming curves.
  • Fully rated magnetic circuit breakers.
  • Auto restart function for day to day operation.
  • Emergency contact input with load-shedding capability on wall mount models.
Smart Pack Wall Mount
The SmartPack Wall Mount unit with SmartLink enabled provides total versatility and convenience for venues requiring low profile permanently installed dimming. The SmartPack Wall Mount unit may be installed with or without other system components, ensuring the lowest possible cost ownership. In addition, a rack mount kit is available for installing the unit into an equipment rack.
Model
Part Number
Channels
Breaker
Voltage/Supply
Notes
SL620W
7021A1100
6
20A
85-140V 47-63Hz
3Ø or 1Ø
SL620W-LPS
7021A1100-LPS
6
20A
with LinkPower Supply
SL1210W
7021A1101
12
10A
SL1210W-LPS
7021A1101-LPS
12
10A
SL1210TPW
7021A1102
12
10A
with ThruPower only
Part Number
Channels
Breaker
Voltage/Supply
Notes
7021A1103
12
10A
230V 47-63Hz
3Ø or 1Ø
7021A1103-LPS
12
10A
with LinkPower supply
7021A1105
12
10A ND
with 2-pole breakers
7021A1105-LPS
12
10A ND
with 2-pole breakers and LinkPower supply
7021A1106
6
15A
7021A1106-LPS
6
15A
7021A1107
6
15A ND
7021A1107-LPS
6
15A ND
7021A1110
3
25A ND
7021A1110-LPS
3
25A ND
7021A1111
12
10A
ThruPower Switch
7021A1112
12
10A ND
ThruPower Switch
7021A1113
12
10A
ThruPower Relay
7021A1114
12
10A ND
ThruPower Relay
7021A1115
12
10A
Relay (only)
7021A1116
12
10A ND
Relay (only)
Smart Pack 19” Portable
The SmartPack Portable dimmer packs are designed in a rugged 19-inch 2-space rack mount package. Ships standard with SmartLink™ enabled for total versatility.
  • UL listed SmartPack Portable dimming packs are available with either six 20A dimmers or twelve 10A dimmers.
  • CE marked SmartPack Portable dimming packs are available with either three 25A dimmers, six 15A dimmers, or twelve 10A dimmers.
In addition the SmartPack 19” Portable pack is available with a wide variety of output panel options to fit industry needs.
UL Rear Panel Options CE Rear Panel Options
6 Channel 12 Channel 3 Channel 6 Channel 12 Channel
Edison Edison Harting Schuko Power Con®
Stage Pin Stage Pin Multi-pin NF French Harting Multipin
Twist-Lock® PowerCon® Terminal Output Swiss Socapex Multipin
Japanese Twist-Lock Dual 6 circuit Multipin CEE 32A, 230V UK 15A Roundpin Terminal Output
PowerCon® Terminal Strip Power Con®
Single 6 circuit Multipin Wireland GST18
Terminal Strip Harting
Socapex
Model
Part Number
Channels
Breaker
Voltage/Supply
Notes
SL620
7020A1000
6
20A
120/240 VAC 1Phase
120/208 VAC 3Phase
with output panel and SmartLink enabled
SL1210
7020A1001
12
10A
Model
Part Number
Channel Count
Breaker Type
Voltage/Supply
Notes
SL325-ND
7021A1106-xx
3
25A ND
230-240 VAC 47-63Hz
with 2-pole breakers and output panel
SL615
7020A1002-xx
6
15A
SL615-ND
7020A1004-xx
6
15A ND
with 2-pole breakers, output panel and SmartLink enabled
SL1210
7020A1003-xx
12
10A
SL1210-ND
7020A1005-xx
12
10A ND
Smart Pack Touring System
The SmartPack Touring system offers small compact design built to travel.
Standard UL Touring rack provides room for two or four SmartPack dimmer packs with the similar output panel options as available in the SmartPack 19” Portable pack. The UL SmartPack Touring system is SmartLink™ enabled and includes built-in mains distribution with options for a main circuit breaker or a Cam-Lok® pass-thru panel.
Standard CE Touring racks are available in a road case with any two SmartPack dimmer packs of your choice with similar output panel options as available with the CE SmartPack 19” Portable pack. The CE SmartPack Touring system is SmartLink™ enabled and includes circuit breaker power distribution per pack with options for a mains breaker and RCD protection, and a convenience outlet for accessories.
All the standard features of the SmartPack Portable unit in an industrial grade road case. Contact ETC for configuration details.
