ColorSource 20 & 20 AV Exploded Diagrams
Pictures show a ColorSource 20. Parts that differ on ColorSource 20 AV are listed in the tables
No Part Number Description
1 7225A4002 Face panel overlay (CS 20)
7225A4012 Face panel overlay (CS 20 AV)
2 4110A4036 Fader cap (single)
3 HWM2108 Screw M3 x 10mm
4 7225A3052 Bottom panel
5 HWM1169 Screw M3 x 5mm
6 7225A4000 Rubber foot strip
7 7225A3023 Rear bottom panel
8 HWM1133 Screw M2.9 x 12mm Plastite a
9 7225A4013 Rear panel EMI shield
10 7225A4015 Rear panel thermal pad
11 HWM1610 Nut M3
12
Factory Replacement Only
Why?
Rear panel
a DMX 5-pin XLR mount screws - CS 20 uses 2, CS 20 AV uses 4 (not pictured)
13 HWM1679 Screw M4 x 10mm
14 7225B5601-CFG Control card kit (CS Console)
7225B5605-CFG Control card kit (CS Console AV)
15 HWM1815 Screw M4 x 8mm
16 7225B5602 Main user interface PCB assembly
17 HWM1802 Screw M4 x 16mm
18 7225A3063 Heat spreader
19 7225A4014 Processor thermal pad
included in control card kit
20 HWM1816 M4 spacer
21 HWM1683 Screw M3 x 6mm
22 7225A4016 6-button keypad strip
23 7225A2017 Numbered key strips
includes both the 1-10 strip and the 11-20 strip
24 7219A4006 Clear key cap (single)
Display
25 7225A3054 Display mounting plate a
26 HWM1810 Screw M2.63 x 6mm
27 HWM1610 Nut M3
28 7225B5604 Display adapter PCB assembly
29 7225A4003 Display adapter mounting tape b
30 7225B2003 Display (touchscreen) a
a if replacing a display from before 2024, also order mounting plate to accommodate new thicker display
b order this tape if replacing touchscreen or display PCB - old tape cannot be reused
31 7225A4101 End cap right
32 7225A3055 Structural end cap right
33 HWM1151 Nut M4
34 7225A3022 Rear top extrusion
35 7225A3050 Face panel
36 7225A3021 Front extrusion
37 HWM1659 Screw M4 x 8mm
38 7225A3053 Structural end cap left
39 HWM1639 Screw M4 x 10mm Taptite
40 7225A4100 End cap left
Other parts not shown in diagrams
M7495 Display to control card ribbon cable
M7503 Display driver PCB to control card ribbon cable
PS450 Power supply
External PSU, no mains lead included
