Face panel overlay and fader caps
| No |
Part Number |
Description |
| 1 |
7225A4102 |
Face panel overlay (CS 40) |
| 7225A4112 |
Face panel overlay (CS 40 AV) |
| 2 |
4110A4036 |
Fader cap (single) |
Bottom and rear covers
| No |
Part Number |
Description |
| 3 |
HWM2108 |
Screw M3 x 10mm |
| 4 |
7225A3152 |
Bottom panel |
| 5 |
HWM1169 |
Screw M3 x 5mm |
| 6 |
7225A4000 |
Rubber foot strip |
| 7 |
7225A3123 |
Rear bottom panel |
| 8 |
HWM1133 |
Screw M2.9 x 12mm Plastite a |
| 9 |
7225A4013 |
Rear panel EMI shield |
| 10 |
7225A4015 |
Rear panel thermal pad |
| 11 |
HWM1610 |
Nut M3 |
| 12 |
Factory Replacement Only
Why?
Rear panel |
a DMX 5-pin XLR mount screws - CS 40 uses 2, CS 40 AV uses 4 (not pictured)
Control card and UI PCB
| No |
Part Number |
Description |
| 13 |
HWM1679 |
Screw M4 x 10mm |
| 14 |
7225B5601-CFG |
Control card kit (CS Console) |
| 7225B5605-CFG |
Control card kit (CS Console AV) |
| 15 |
HWM1815 |
Screw M4 x 8mm |
| 16 |
7225B5602 |
Main user interface PCB assembly |
| 17 |
HWM1802 |
Screw M4 x 16mm |
| 18 |
7225A3063 |
Heat spreader |
| 19 |
7225A4014 |
Processor thermal pad
included in control card kit |
| 20 |
HWM1816 |
M4 spacer |
| 21 |
HWM1683 |
Screw M3 x 6mm |
| 22 |
7225A4016 |
6-button keypad strip |
| 23 |
7225A2018 |
Numbered key strips
includes all 4 strips of 10:
1-10
11-20
21-30
31-40 |
| 24 |
7219A4006 |
Clear key cap (single) |
| 41 |
7225B5603 |
User interface extension PCB assembly |
Display
ColorSource 20 shown, display parts are the same
| No |
Part Number |
Description |
| 25 |
7225A3054 |
Display mounting plate a |
| 26 |
HWM1810 |
Screw M2.63 x 6mm |
| 27 |
HWM1610 |
Nut M3 |
| 28 |
7225B5604 |
Display adapter PCB assembly |
| 29 |
7225A4003 |
Display adapter mounting tape b |
| 30 |
7225B2003 |
Display (touchscreen) a |
a if replacing a display from before 2024, also order mounting plate to accommodate new thicker display
b order this tape if replacing touchscreen or display PCB - old tape cannot be reused
Outer body
| No |
Part Number |
Description |
| 31 |
7225A4101 |
End cap right |
| 32 |
7225A3055 |
Structural end cap right |
| 33 |
HWM1151 |
Nut M4 |
| 34 |
7225A3122 |
Rear top extrusion |
| 35 |
7225A3150 |
Face panel |
| 36 |
7225A3121 |
Front extrusion |
| 37 |
HWM1659 |
Screw M4 x 8mm |
| 38 |
7225A3053 |
Structural end cap left |
| 39 |
HWM1639 |
Screw M4 x 10mm Taptite |
| 40 |
7225A4100 |
End cap left |
Other parts not shown in diagrams
| Part Number |
Description |
| M7495 |
Display to control card ribbon cable |
| M7503 |
Display driver PCB to control card ribbon cable |
| M7493 |
Flat cable between main UI PCB and extension PCB |
| PS450 |
Power supply
External PSU, no mains lead included |
