ColorSource Console Common Spares
This article is intended to complement the exploded diagrams articles, providing a quick reference to the most commonly requested spare parts
| Component | Part Number | Notes | ||||
| Power supply | PS450 | External PSU, no mains lead included | ||||
| Main control card |
Control card is the same for 20 and 40, but different between regular and AV 🔀 replaces 7225B5705-CFG (regular) 🔀 replaces 7225B5701-CFG (AV) |
| ColorSource UI Main Assembly | 7225B5602 | Fader PCB, used in all consoles | ||||
| ColorSource UI Extension Assy | 7225B5603 | Additional 20 faders, used in ColorSource 40 (AV) consoles only | ||||
| Fader cap | 4110A4036 | |||||
| Individual fader | P152-F | Including fader dust cover Requires soldering |
| Display (touchscreen) | 7225B2003 | As of late 2024, this screen is thicker, and you should order a 7225A3054 mounting plate to accommodate it in older consoles 🔀 replaces 7225B2001 and 7225B2002 |
| Display mounting plate | 7225A3054 | This version has larger notch to accommodate thicker screen, see above |
| Display adapter PCB assembly | 7225B5604 | |||||
| Display adapter mounting tape | 7225A4003 | Piece of double-sided tape, used to hold the adapter PCB to the rear of the display |
