ColorSource PAR Common Spares
This article is intended to complement the exploded diagrams article, providing a quick reference to the most commonly requested spare parts
Component Part Number Notes
Control card & array kit
12v Fan (3 wire)
ColorSource PAR XLR 7412K1013-1.7.2
ColorSource PAR Deep Blue XLR 7412K1015-1.7.2
48v Fan (2 wire)
ColorSource PAR XLR 7412K1003-x.x.x
ColorSource PAR RJ45 7412K1004-x.x.x
ColorSource PAR Deep Blue XLR 7412K1005-x.x.x
ColorSource PAR Deep Blue RJ45 7412K1006-x.x.x
ColorSource PAR Pearl XLR 7412K1007-x.x.x
ColorSource PAR Pearl RJ45 7412K1008-x.x.x
Choose the kit that matches your array type, DMX connector, and the fan fitted in your fixture
The control card and array must always be replaced as a pair from the same kit
-x.x.x represents the firmware version pre-installed on the control card. Contact your dealer or ETC office to see which version is currently shipping
See the Revisions article for information about fans and control cards
 Power supply  PS404
Fan
7412B2001 48V Fan
7414B2001 12V Fan
 Body enclosure left 7412A3001 Left and right as seen from behind the fixture with gel clip at top
Body enclosure right inc. clutch plate 7412A2001 Left and right as seen from behind the fixture with gel clip at top
Lens (single) OP2077
Control card switch (up/down/mode) S621-F Requires soldering
Control card DMX in connector (male) J61122-F Requires soldering
Control card DMX thru connector (female) J61121-F Requires soldering
