ColorSource PAR Revisions
Different Fans
Between 2020 and 2026, ColorSource PAR was made with 2 different fans depending on parts availability
| Revision | Voltage | Wires | Part Number of Fan |
| Original | 48V | 2 | 7412B2001 |
| Alternate | 12V | 3 | 7414B2001 |
How to tell which fan is fitted
Option 1: Contact ETC tech service with the fixture's serial number
Option 2: Follow the repair guide and look at the fan wires in step 6
Choosing replacement parts
At this time, both fans remain available to buy from ETC
In case of fan failure, order the same fan and replace
In case of control card failure, order the relevant kit for the fan type you have - see Common Spares or Exploded Diagrams
Images
| Original | ![]() |
| Alternate | ![]() |
