ColorSource Par V Zoom Exploded Diagrams
The ColorSource Par V Zoom has only 2 variants - with and without Multiverse. Differences are called out below
Parts with a ðŸŽ¨ can have a suffix added for different colours. For example:
7412A3008        yoke (black)
7412A3008-1    yoke (white)
7412A3008-5    yoke (silver)
Plastic parts and stickers are generally only available on black or white
Yoke and outer body
No Part Number Description
1 HW8144🎨 Tilt lock handle
2 HW522 Flat washer 1/4"
3 7412A3008 ðŸŽ¨ Yoke (bare) a
4 HW5125 Bolt 5/16-18 .75
5 HWM2001 Bolt M6 x 14mm hex
6 7470A3019 Clutch plate
7 HWM1986 Screw M4 x 8mm
a Bare painted yoke not including labels. Not all labels can be ordered
Body shell and lenses
8 7421A4002 Front lens (diffused)
9 7421A4003 Front lens rotator
10 7421A3007 Lens retainer clip
11 7421A4017 Rear lens (clear)
12 7421A4004 Fresnel lens
13 7421A4018 Diffusion
14 7421A4001 Reflector
15 7421A3002 ðŸŽ¨ Right housing
16 7421A3008 Gel clip
17 HW750 Gel clip spring
18 HWM1948 Screw M4 x 10mm
19 7421A3001 ðŸŽ¨ Left housing
20 HW2154 Screw 6 x 1/2
21 7421A4015 ðŸŽ¨ Zoom knob
22 7421A4011 ðŸŽ¨ Zoom knob bushing
23 7421A4014 Zoom gear
Rear plate, power input and wireless
24 N1084 Multiverse antenna
25 7423A4001 NFC/antenna holder
26 7423B5603 NFC PCB
27 HWM1133 Screw M2.9 x 12mm plastite
28 HWM2108 Screw M3 x 10mm
29 7421A4007 ðŸŽ¨ Sticker - power
30 HWM1151 Nut M4
31 J2513 Power in/thru assembly
32 J2525 Power assembly bracket
33 HW1253 SCR #4-20 x 5/16 plastite
34 7421A3006 ðŸŽ¨ Fan grille / UI tray
35 7421A4008 ðŸŽ¨ Sticker - UI
Control card & PSU assembly
36 HWM1546 Screw M3 x 8mm
37 7421A3009 PSU shield
38 7421A4013 PSU insulator
39 PS496 Power supply
40 HWM1151 Nut M4
41 Kit, see below Control card
Fan
42 HWM1546 Screw M3 x 8mm
43 7412A3005 Chassis
44 7417B2001 Fan
45 HWM1151 Nut M4
Array and heatsink
46 HWM1546 Screw M3 x 8mm
47 7421A3004 Heatsink bracket
48 Kit, see below LED array
49 7421A3003 Heatsink
Control card and array kits
Array calibration is held on the control card, so array and control card must always be replaced as a pair from the same kit
Each kit contains the array, control card, thermal pads, and some spare screws. Re-use existing screws and wiring harnesses
ColorSource Par V Zoom with Multiverse 7421K1004-x.x.x
ColorSource Par V Zoom without Multiverse 7421K1005-x.x.x
Kits may have different firmware versions loaded. Ask your ETC office or dealer which version is current and/or in stock in your region.
Other parts not shown on diagrams
J61122-F Male XLR connector on control card (requires soldering)
J61121-F Female XLR connector on control card (requires soldering)
S621-F Up/Down/Mode switch on control card (requires soldering)
 Contact ETC tech service for any other parts, including wiring not listed here
