ColorSource Spot Jr Exploded Diagrams
The 2 variants of ColorSource Spot Jr (Regular and Deep Blue) share most of their parts in common. Differences are called out below
Parts with a 🎨 can have a suffix added for different colours. For example:
7412A3008 yoke (black)
7412A3008-1 yoke (white)
Note: this fixture and its parts are only available in black or white
ColorSource Jr fixtures use plastic components, and taptite screws that screw into these components. Repeated dis- and re-assembly or overtightening will weaken the plastic and cause it to fail. Remove and re-insert screws very gently, and only as many times as required to repair your fixture. Do not use power tools under any circumstances
Top casing and external fixings |
Optical assembly attachment |
Lens rails
Array, beam tube and heatsink
Shutter assembly
a The complete shutter kit contains all the parts shown here, plus a fourth shutter blade complete with its handle, pre-assembled |
Lens assemblies
Yoke and fixings
a Bare painted yoke - this fixture doesn't use yoke stickers. |
Electronics assembly attachment
Control card and fan
Power supply (original)Replace power supply like-for-like, as the mounting shown here, and part 53 above, differ between the two types
Power supply (new)Replace power supply like-for-like, as the mounting shown here, and part 53 above, differ between the two types
Control card and array kitsArray calibration is held on the control card, so array and control card must always be replaced as a pair from the same kit Each kit contains the array, control card, thermal pads, and some spare screws. Re-use existing screws and wiring harnesses |
-x.x.x represents the firmware version pre-installed on the control card. |
Other parts not shown on diagrams
Contact ETC tech service for any other parts, including wiring, not listed here |
