Desire D22 Canopy Exploded Diagrams
Parts with a ðŸŽ¨ can have a suffix added for different colours. For example:
7411A3015          yoke (black)
7411A3015 -1    yoke (white)
7411A3015 -5    yoke (silver)
Plastic parts and stickers are generally only available on black or white
Yoke and canopy mount
No Part Number Description
1 HW375 Nut 8-32
2 HWM3118 Washer toothed M12
3 7411A3012 Canopy backer plate
4 HW5548 Flat washer
5 7063A3027 ðŸŽ¨ Canopy
6 7411A3022 ðŸŽ¨ Canopy rotator
7 HW5538 Anti-rotation washer
8 7411A3015 ðŸŽ¨ Yoke (bare) a
9 HW5549 Wavy washer
10 HW5550 Nut 1/4
11 HW8495 Tilt lock knob
12 HWM2244 Flat washer
13 HWM2246 Bolt M6 x 12mm
14 HWM1712 Set screw M4 x 8mm
15 TBC was HW309 Screw 8-32
a Bare painted yoke not including labels. Not all labels can be ordered
Complete kit
D22 Canopy termination kit 7411K1023 🎨
Kit contains all the parts below. Blue CUI DMX connectors only, orange connector version no longer available
Components
16 HW1123 Screw 4-40 x 3/16
17 7410B5918 DMX termination assembly b
18 HW351-1 Screw #8 x 5/16
19 7411B7016 Canopy ground wire
20 7411A4013 DMX thru label
21 HW375 Nut 8-32
22 7411A4012 DMX in label
23 7411A3011 ðŸŽ¨ Connector cover
24 7411A4011 DMX and termination label
25 SGHW1247 Hook (1" x 8-32)
26 J3895 Terminal block 3 position
27 7411A4010 AC input label
28 HW316 Screw 8-32 x 7/8"
b Older fixtures used orange Weidmuller connectors. These are no longer available. If replacing this PCB, order new termination kits too
PSU, control card and UI (Track & Canopy)
5 HWM1644 Screw M4 x 10mm
6 7411K1019-x.x.x* Control card kit
7 7411K1018 Power supply (CE)
7411K1020 Power supply (ETL)
9 HWM1639 Screw M4 x 10mm
10 HWM1017 Split washer
11 7411A3001 ðŸŽ¨ Rear enclosure
12 7411A2004 UI sticker (Lustr+)
7411A2008 UI sticker (Studio HD)
7411A2005 UI sticker (Daylight)
7411A2006 UI sticker (Tungsten)
13 7410A4012 Display window
15 HW6734 Strain relief bushing
*-x.x.x represents the firmware version pre-installed on the control card.
Rear body into front body
1 HWM2007 Nut M6
2 7411A3010 Enclosure cover
3 HWM1618 Screw M4 x 12mm
LED housing and array
1 7410A3026 Gel clip
2 HWM1648 Screw M4 x 10mm
3 HW750 Spring 0.5"
4 7411A3003 ðŸŽ¨ Gel clip retainer
5 7411A3004 ðŸŽ¨ Trim ring with ears
6 HWM1037 Screw M3 x 20mm
7 7411A4001 LED optic
8 HWM2235 Screw M3 x 10mm
9 7411B5605-CFG LED array (Studio HD)
7411B5604-CFG LED array (Daylight)
 7411B5704-CFG LED array (Tungsten)
7411B5603-CFG LED array (Lustr+)
10 7411A4002 LED array thermal pad
included in array kits (9)
11 7411A3002 ðŸŽ¨ LED head
12 HWM1618 Screw M4 x 12mm
