Desire D22 Portable Exploded Diagrams
- Last updated
Save as PDF
Parts with a 🎨 can have a suffix added for different colours. For example:
7411A3015 yoke (black)
7411A3015 -1 yoke (white)
7411A3015 -5 yoke (silver)
Plastic parts and stickers are generally only available on black or white
Yoke
| No |
Part Number |
Description |
| 1 |
7411A3015 🎨 |
Yoke (bare) a |
| 2 |
HW8495 |
Tilt lock knob |
| 3 |
HWM2244 |
Flat washer |
| 4 |
HWM2246 |
Bolt M6 x 12mm |
a Bare painted yoke not including labels. Not all labels can be ordered
Rear body into front body
| No |
Part Number |
Description |
| 1 |
HWM2007 |
Nut M6 |
| 2 |
7411A3010 |
Enclosure cover |
| 3 |
HWM1618 |
Screw M4 x 12mm |
PSU, control card and UI
| No |
Part Number |
Description |
| 5 |
HWM1644 |
Screw M4 x 10mm |
| 6 |
7411K1019-x.x.x* |
Control card kit |
| 7 |
7411K1018 |
Power supply (CE) |
| 7411K1020 |
Power supply (ETL) |
| 8 |
7410B5615 |
DMX in/thru PCB |
| 9 |
HWM1639 |
Screw M4 x 10mm |
| 10 |
HWM1017 |
Split washer |
| 11 |
7411A3005 🎨 |
Rear enclosure |
| 12 |
7411A2001 |
UI sticker (Lustr+) |
| 7411A2007 |
UI sticker (Studio HD) |
| 7411A2002 |
UI sticker (Daylight) |
| 7411A2003 |
UI sticker (Tungsten) |
| 13 |
7410A4012 |
Display window |
| 14 |
HW1169 |
Screw 4-40 x 3/8 (XLR) |
| 15 |
HW6734 |
Strain relief bushing |
*-x.x.x represents the firmware version pre-installed on the control card.
LED housing and array
| No |
Part Number |
Description |
| 1 |
7410A3026 |
Gel clip |
| 2 |
HWM1648 |
Screw M4 x 10mm |
| 3 |
HW750 |
Spring 0.5" |
| 4 |
7411A3003 🎨 |
Gel clip retainer |
| 5 |
7411A3004 🎨 |
Trim ring with ears |
| 6 |
HWM1037 |
Screw M3 x 20mm |
| 7 |
7411A4001 |
LED optic |
| 8 |
HWM2235 |
Screw M3 x 10mm |
| 9 |
7411B5605-CFG |
LED array (Studio HD) |
| 7411B5604-CFG |
LED array (Daylight) |
| 7411B5704-CFG |
LED array (Tungsten) |
| 7411B5603-CFG |
LED array (Lustr+) |
| 10 |
7411A4002 |
LED array thermal pad
included in array kits (9) |
| 11 |
7411A3002 🎨 |
LED head |
| 12 |
HWM1618 |
Screw M4 x 12mm |
