Desire D22 Track Exploded Diagrams
Parts with a ðŸŽ¨ can have a suffix added for different colours. For example:
7411A3015          yoke (black)
7411A3015 -1    yoke (white)
7411A3015 -5    yoke (silver)
Plastic parts and stickers are generally only available on black or white
Yoke and track adapter
No Part Number Description
1 Contact ETC Track adapter
2 7411A3023 Track bracket
3 HWM10075 Screw M3 x 18mm
4 HW5548 Flat washer
5 HW6758 Strain relief
6 HW5536 Retaining collar
7 HW5538 Anti-rotation washer
8 7411A3015 🎨 Yoke (bare) a
9 HW5549 Wavy washer
10 HW5550 Nut 1/4
11 HW8495 Tilt lock knob
12 HWM2244 Flat washer
13 HWM2246 Bolt M6 x 12mm
a Bare painted yoke not including labels. Not all labels can be ordered
PSU, control card and UI (Track & Canopy)
5 HWM1644 Screw M4 x 10mm
6 7411K1019-x.x.x* Control card kit
7 7411K1018 Power supply (CE)
7411K1020 Power supply (ETL)
9 HWM1639 Screw M4 x 10mm
10 HWM1017 Split washer
11 7411A3001 ðŸŽ¨ Rear enclosure
12 7411A2004 UI sticker (Lustr+)
7411A2008 UI sticker (Studio HD)
7411A2005 UI sticker (Daylight)
7411A2006 UI sticker (Tungsten)
13 7410A4012 Display window
15 HW6734 Strain relief bushing
*-x.x.x represents the firmware version pre-installed on the control card.
Rear body into front body
1 HWM2007 Nut M6
2 7411A3010 Enclosure cover
3 HWM1618 Screw M4 x 12mm
LED housing and array
1 7410A3026 Gel clip
2 HWM1648 Screw M4 x 10mm
3 HW750 Spring 0.5"
4 7411A3003 ðŸŽ¨ Gel clip retainer
5 7411A3004 ðŸŽ¨ Trim ring with ears
6 HWM1037 Screw M3 x 20mm
7 7411A4001 LED optic
8 HWM2235 Screw M3 x 10mm
9 7411B5605-CFG LED array (Studio HD)
7411B5604-CFG LED array (Daylight)
 7411B5704-CFG LED array (Tungsten)
7411B5603-CFG LED array (Lustr+)
10 7411A4002 LED array thermal pad
included in array kits (9)
11 7411A3002 ðŸŽ¨ LED head
12 HWM1618 Screw M4 x 12mm
