Desire D40 Exploded Diagrams
Desire D40 has been made with 7 different LED arrays - only the array PCB and rear UI sticker differ between these
Parts with a ðŸŽ¨  can have a suffix added for different colours. For example:
7410A3025          yoke (black)
7410A3025 -1    yoke (white)
7410A3025 -5    yoke (silver)
Plastic parts and stickers are generally only available on black or white
Because Desire D40 and D60 share many parts, pictures may not match your fixture exactly, but the part numbers are correct
Yoke
No Part Number Description
1 7410A3025 ðŸŽ¨ Yoke, D40 (bare) a
7410A3037 🎨 Yoke, D60 (bare) a
2 HW8460 Tilt lock knob
3 HW5256 Flat washer
4 HWM2228 Bolt M8 x 18mm
a Bare painted yoke not including labels. Not all labels can be ordered
Rear housing to front housing
5 HWM1749 Screw M5 x 16mm a
a Screw head has varied, thread and length have remained the same. Currently shipping screw fits all fixtures
PSU, control card, UI
6 7410A3031 Compression spar
7 7410K4003-1.8.2 Control card
Includes support tray and thermal pad
8 HWM1644 Screw M4 x 10mm
9 7410K4001 Power supply
10 7410A3012 LCD support bracket
11 DS183-F LCD display
12 7410B5615 DMX in/thru PCB
13 7410B5607 Powercon in/thru PCB
14 7410A3028 ðŸŽ¨ Rear enclosure
15 7410A4012 Display window
16 HW1169 Screw 4-40 x 3/8 (XLR)
17 HWM2108 Screw M3 x 10mm (Powercon)
18 7410A2001 UI sticker (Vivid)
7410A2002 UI sticker (Studio HD)
7410A2003 UI sticker (Fire)
7410A2004 UI sticker (Ice)
7410A2005 UI sticker (Lustr+)
7410A2031 UI sticker (Daylight)
7410A2033 UI sticker (Tungsten)
Rear of LED head
20 HWM1644 Screw M4 x 10mm
21 7410A3033 Enclosure cover
28 HWM2229 Nut M8
LED head and array (D40)
30 HWM1648 Screw M4 x 10mm
31 7410A3027 ðŸŽ¨ Gel clip retainer
32 7410A3026 Gel clip
33 HW750 Spring 0.5"
  7410K4008 ðŸŽ¨ Gel clip replacement kit
includes parts 30 (x2), 31,32, 33
34 7410A3004 ðŸŽ¨ Trim ring with ears
35 HWM1751 Screw M3.5 x 20mm
36 7410A4002 Front gasket
37 7410A4001 Front glass
38 7410A4131 Single-piece optic assembly a
40 7410B5604-CFG LED array (Vivid)
7410B5613-CFG LED array (Lustr+)
7410B5609-CFG LED array (Studio HD)
7410B5716-CFG LED array (Tungsten)
7410B5616-CFG LED array (Daylight)
 7410B5803-CFG LED array (Fire)
7410B5703-CFG LED array (Ice)
41 7410A4019 LED array thermal pad
Included with array kit (40)
44 7410A3002 ðŸŽ¨ LED head
45 HWM1749 Screw M5 x 16mm b
a This is the one-piece optic used after July 2015. If your fixture has an optic consisting of lenses sandwiched between 2 plates, contact ETC for guidance
b Screw head has varied, thread and length have remained the same. Currently shipping screw fits all fixtures
