Desire D60 Exploded Diagrams
Desire D60 has been made with 7 different LED arrays - only the array PCB and rear UI sticker differ between these
Parts with a ðŸŽ¨ can have a suffix added for different colours. For example:
7410A3037          yoke (black)
7410A3037 -1    yoke (white)
7410A3037 -5    yoke (silver)
Plastic parts and stickers are generally only available on black or white
Because Desire D40 and D60 share many parts, pictures may not match your fixture exactly, but the part numbers are correct
Yoke
No Part Number Description
1 7410A3025 ðŸŽ¨ Yoke, D40 (bare) a
7410A3037 🎨 Yoke, D60 (bare) a
2 HW8460 Tilt lock knob
3 HW5256 Flat washer
4 HWM2228 Bolt M8 x 18mm
a Bare painted yoke not including labels. Not all labels can be ordered
Rear housing to front housing
5 HWM1749 Screw M5 x 16mm a
a Screw head has varied, thread and length have remained the same. Currently shipping screw fits all fixtures
PSU, control card, UI
6 7410A3031 Compression spar
7 7410K4003-1.8.2 Control card
Includes support tray and thermal pad
8 HWM1644 Screw M4 x 10mm
9 7410K4001 Power supply
10 7410A3012 LCD support bracket
11 DS183-F LCD display
12 7410B5615 DMX in/thru PCB
13 7410B5607 Powercon in/thru PCB
14 7410A3028 ðŸŽ¨ Rear enclosure
15 7410A4012 Display window
16 HW1169 Screw 4-40 x 3/8 (XLR)
17 HWM2108 Screw M3 x 10mm (Powercon)
18 7410A2001 UI sticker (Vivid)
7410A2002 UI sticker (Studio HD)
7410A2003 UI sticker (Fire)
7410A2004 UI sticker (Ice)
7410A2005 UI sticker (Lustr+)
7410A2031 UI sticker (Daylight)
7410A2033 UI sticker (Tungsten)
Fan, rear of LED head
19 HWM2108 Screw M3 x 10mm
20 HWM1644 Screw M4 x 10mm
21 7410A3033 Enclosure cover
22 7410B2003 D60 fan
23 7410A3034 ðŸŽ¨ Main mount cover
24 7410A3035 Fan support
25 HWM2105 Screw M3 x 10mm
26 HWM1609 Screw M5 x 10mm Plastite (fan)
27 HW6163 Tubing 3/8"
(per foot, ~0.5 ft per fixture, in 2 pieces)
28 HWM2229 Nut M8
LED head and array (D60)
30 HWM1648 Screw M4 x 10mm
31 7410A3027 ðŸŽ¨ Gel clip retainer
32 7410A3026 Gel clip
33 HW750 Spring 0.5"
  7410K4008 ðŸŽ¨ Gel clip replacement kit
includes parts 30 (x2), 31,32, 33
34 7410A3007 ðŸŽ¨ Trim ring with ears
35 HWM1645 Screw M3.5 x 10mm
36 7410A4004 Front gasket
37 7410A4003 Front glass
38 7410A2036 Optic assembly
39 HWM7041 Standoff M3.5 x 12mm
40 7410B5611-CFG LED array (Vivid)
7410B5614-CFG LED array (Lustr+)
 7410B5612-CFG LED array (Studio HD)
7410B5717-CFG LED array (Tungsten)
7410B5617-CFG LED array (Daylight)
7410B5810-CFG LED array (Fire)
7410B5710-CFG LED array (Ice)
41 7410A4020 LED array thermal pad
Included with array kit (40)
42 HWM1652 Screw M3.5 x 6mm
43 7410A3038 Cable channel cover
44 7410A3005 ðŸŽ¨ LED head
45 HWM1749 Screw M5 x 16mm a
