Desire Fresnel Complete Repair Guide
Tools required
- Torx 20 driver
- PH2 screwdriver
- PZ2 screwdriver
- PH1 screwdriver
- Wago 2059 poking tool or paperclip
- 10mm socket/wrench
Steps to repair
The steps below detail how to strip down a Desire Fresnel to the casing. It is recommended to read through the whole document before starting, so as not to unnecessarily dismantle a part that can stay intact.
For any questions or concerns, please contact your local ETC tech service department.
Disconnect mains power before servicing, and wait at least 1 hour before starting work so that capacitors can discharge. Only proceed if you feel comfortable doing so
Look out for the following symbols in the repair guide
⚠️Warnings - these give advice on avoiding damage to (other) components
ℹ️Information - these give helpful tips to save you work or get into tricky places
🛠️ Reassembly notes - tips when following the instructions in reverse to reassemble the device
1: Opening the Fixture
1.1 Remove the 13mm bolts from the yolk on both sides. There will be 2 washers underneath each bolt. Keep the brass bushing attached to the pivot slider, be sure not to lose them. |
1.2 Remove the clutch plate handle. The screw will stay in until the yoke is removed. |
1.3 Remove the yoke handle. |
| 1.4 Undo 3 screws holding the lens cover clamshell together on top of the fixture. | ![]() ![]() |
| 1.5 Carefully allow each side of the clamshell to rotate away from each other until they stop, then lift upwards. Each side is held in by a flange that rotates into a slot on the base of the fixture, so they won't simply pull out without rotating out sideways. | ![]() |
2: LED Array Replacement
2.1 Undo 6 screws, 3 on each side, remove the zoom indicators. |
| 2.2 Adjust the zoom knob until you see the screw on the zoom drive rod. Undo screw on each side, remove the middle baffle and the zoom lens holder. | ![]() ![]() |
| 2.3 Undo 4 screws, remove the base baffle. |
| 2.4 Undo 2 screws to remove the mixing tube. | ![]() |
| 2.5 Undo 8 screws and 4 connectors on the LED Array. | ![]() |
| 2.6 Remove the LED array and thermal pad and replace both. |
3: Removing the face panel
3.1 Remove the 1" wide, white ribbon cable from the top of the fixture by pushing down the black locking bar. Keep the ribbon cable attached to the face panel. Note: The ribbon cable socket is counter intuitive in that it looks like it's unlocking when it's actually locking and vise versa. Push the locking bar TOWARD the ribbon cable to loosen it and away from the ribbon cable to lock. |
3.2 Undo 1 screw, remove the focus knob from the back of the fixture.
3.3 Undo 4 screws holding the faceplate frame around the DMX panel.
CAUTION: Be very careful when pulling the face panel away from the fixture as there are some very tight harnesses with very fragile connectors inside. Only pull it away as much as is needed to get to the harnesses and disconnect them. |
| 3.4 Remove the AC harness connector and the ground wire blade terminal from the back of the face panel. Use pliers if needed. | ![]() |
3.5 Remove the DC power harness. Note: Use WAGO 206-859 demounting tool to apply gentle force and pull the cable at the same time. |
Front view of the chassis with PCBs labeled. |
4: Replacing the Control Card
| 4.1 Detach 4 knobs on the front of face panel. |
4.2 Undo 4 screws and 4 connectors on the control card.
CAUTION: Be very careful upon reassembly when pushing the face panel back into place. DO NOT FORCE IT AT ALL. If you feel ANY resistance, check the wires and harnesses inside for proper routing, especially the many large ferrites that get in the way. If you just slam it together, it WILL crimp/cut wires and/or break connectors. |
5: Powercon/DMX Assy. Replacement
| 5.1 Remove 6 connectors on the Powercon/DMX Assy. Use pliers if needed. |
| 5.2 Undo screws on Powercon and DMX connectors. |
| 5.3 Remove the Powercon/DMX Assy. and the DMX spacer. |
| 5.4 Replace the Powercon/DMX Assy. with a good one. |
6: NFC Assy. replacement
| 6.1 Undo 1 screw and 1 connectors on the control card. Remove the clamp. | ![]() |
| 6.2 Unlock and lift up the mounting plate. |
| 6.3 Undo 1 connector on the NFC Assy. | ![]() |
| 6.4 Remove the NFC Assy. from the mounting plate. Replace with new one. |
7: Driver Card Replacement
7.1 Undo 8 screws and 9 connectors on the Generic driver Assy.
| 7.2 Remove card and replace with new one. |
8: Removing the Zoom Assy./Replacing Power Supply
| 8.1 Undo 1 connector on the Generic driver Assy. | ![]() |
8.2 Adjust the zoom knob and leave a space for the front end cap removal.
CAUTION: Springs inside, please use safety glasses while servicing the zoom knob. |
| 8.3 Undo 1 screw on zoom knob and carefully pull the zoom knob off the shaft. |
| 8.4 Remove 2 springs, then remove the cylindrical discs. | ![]() |
| 8.5 Undo 4 screws, remove the front end cap. | ![]() |
| 8.6 Undo 8 screws on the base extrusion. |
| 8.7 Turn the fixture upside down and carefully lift the base extrusion upwards. |
| 8.8 Now you have access to the power supply. | ![]() |
| 8.9 Undo 4 screws and 3 connectors on the PSU. | ![]() |
| 8.10 Remove the PSU. Before installing new PSU, make sure the insulator underneath the PSU doesn’t have any holes in it. Replace with new. |
Reassembly notes
Note: When reassembly the front zoom knob, inspect the internal mechanism to make sure the flat sides of the zoom assembly shaft are parallel to the spring pockets. Then carefully place the knob back into position by aligning the two tabs on the underside of the knob into the two pockets on either side of the cylindrical disks.
