Desire Fresnel Complete Service Guide
Tools required
- Torx 20 driver
- PH2 screwdriver
- PZ2 screwdriver
- PH1 screwdriver
- Plastic spudger
- Wago 2059 poking tool or paperclip
- 7mm nut spinner
- 10mm spanner/wrench (yoke bolts)
[List required tools above. If a certain tool is only needed for a specific task, which may not be completed every time, note this in brackets]
Steps to repair
The steps below detail how to strip down a Color Source Linear to the casing. It is recommended to read through the whole document before starting, so as not to unnecessarily dismantle a part that can stay intact.
For any questions or concerns, please contact your local ETC tech service department.
Disconnect mains power before servicing, and wait at least 1 hour before starting work so that capacitors can discharge. Only proceed if you feel comfortable doing so
Look out for the following symbols in the repair guide
⚠️Warnings - these give advice on avoiding damage to (other) components
ℹ️Information - these give helpful tips to save you work or get into tricky places
🛠️ Reassembly notes - tips when following the instructions in reverse to reassemble the device
[Optional information box, explaining conventions used in the article. Delete if not needed]
[Section 1 Title]
1. Description of step 1 |
Pic 1 goes here |
2. Description of step 2 |
Pic 2 goes here |
3. Description of step 2 |
Pic 3 goes here |
[Section 2 Title]
4. Description of step 4 Number through the sections so each step has a unique number in the article |
Pic 4 goes here |
[Section 3 Title]
Notes can go in this area
Also information that you can skip steps X to Y before beginning this section
5. |
[Section 4 Title]
[Section 5 Title]
Reassembly notes
Use this section for detailed or important reassembly notes that don't fit nicely into the disassembly flow Use additional pictures as required
